JAMESs Web Site
Date:  4-28-2015
Manual Reference:  14.2
Brief Description:  Sand sealer primer and add Z Grip bondo
Tonight I sanded the sealer primer to find low areas and see the scratches in the Micro. The sealer is very hard and 80-120 grit was used to get the results I wonted. I then used Z Grip bondo to fill in the low areas and a few deep scratches.
I will see how it sands out and if I’m not happy I will go to the Spot- Lite bondo and fill with this stuff. The wings were very close before I sprayed the sealer on so the bondo work should be fast and then the K2 primer comes out to play.
Sealer sanded
Sealer sanded
Lots of Shmag on the floor
Z Grip bondo in low areas
Copyright © 2001-2018 Matronics. All Rights Reserved.
