JAMESs Web Site
Date:  4-7-2015
Number of Hours:  3.00
Manual Reference:  14.2
Brief Description:  Found a few bigger areas needing work
I blocked out the bottom Pilot strake and then worked on the top and found a few areas needing work. The Pilot door was one spot and then a bigger area on the top strake. The pinholes are getting filled and not many of them left to do. A few shots of primer on these areas and then block out again. I still have the bottom to do and will need to use my creeper for this to roll around on.
Pilot side door needs blending
Filler added to door
A low area needed filler
Copyright © 2001-2018 Matronics. All Rights Reserved.
