JAMESs Web Site
Date:  3-16-2015
Manual Reference:  14.2
Brief Description:  Fill and sand in Canard- Fuselage area.
Fill and sand in Canard- Fuselage area was the job for tonight. It took 3 applications of Z-Grip and Spot-Lite to get the rite feeling and feathered in.
Spot-Lite is the only bondo to use as you get close to the final level and fill needed for that perfect job. It sands so nice and feathers right down to a hair or less. It is only mills thick when done, a must for body work. Application to sanding is only 10 minutes as glazing putty or small fill areas.
Ready for primer
Ready for primer
Spot - Lite over Z-Grip bondo
All most ready for primer
Copyright © 2001-2017 Matronics. All Rights Reserved.
