JAMESs Web Site
Date:  3-10-2015
Number of Hours:  3.00
Manual Reference:  14.2
Brief Description:  More sanding on the NACA inlets
I did more filling and sanding on the NACA scoops they will be ready for primer soon.
I also filed and sanded the transition on the air and heater inlets on the NACA scoops so the air flowing down the fuselage will flow smoothly into the inlet. On the oil cooler there is sharp deep transition and the air will flow past and will not completely follow the fuselage curve into the oil cooler. Air flowing stays on the surface just like water going around a rock in the river.
Filling and sanding.
Front tapered for laminar air flow
Good transition
Good transition
Copyright © 2001-2018 Matronics. All Rights Reserved.
