JAMESs Web Site
Date:  2-22-2015
Number of Hours:  8.00
Manual Reference:  14.2
Brief Description:  Filling and sanding low areas on strakes
I am filling and sanding the low areas on the strakes and fuselage with Z-Grip and Spot-lite bondo. I’m starting to see the light at the end of the tonal it is a long way to get there but the light can be seen. I find that the Spot-lite 2 part putty is great to work with and shape with 80 grit sand paper. Z-Grip is used for the bigger areas needing filling. I still go back to sand able Epoxy and micro balloons for the very big areas needing filling or shaping.
Low areas have to be filled
Small areas get filling
Taking shape
Taking shape
Copyright © 2001-2018 Matronics. All Rights Reserved.
