JAMESs Web Site
Date:  2-15-2015
Number of Hours:  4.00
Manual Reference:  14.2
Brief Description:  Block out strake and add filler were needed
I added micro to the bottom strake at the spare to be level with the wing when it is bolted on. I sanded out the stake on the Co-Pilot side and filled the small areas and some of the small areas turned into big areas, but that is to be expected when you can’t remove the high spot which is the fiber glass, so lows have to come up.
Small low areas sanded out
Just a few more areas to fill
