JAMESs Web Site
Date:  1-29-2015
Number of Hours:  6.00
Manual Reference:  14.2
Brief Description:  More sanding and primer on strakes Happy
I got the sanding done from yesterdays work and that was a few hours of work. I had a few more spots to bondo on the winglets before I spay on the primer sealer. I find that the primer sealer is hard and it stops me from dinging into the soft micro when sanding the bondo helping keep the wings and winglets more flat.
Wow I got primer sealer on the strakes and now I can work on the small stuff that needs filling and feathering out.
I find that with the white micro on white micro it’s really hard to see where the small areas need work so the primer will help here. I only spay one coat at a time and work out stuff from there. I’m trying to keep the weight down only using enough primer to do what needs to be done.
Winglets primed and sealed
Stakes got primed and sealed
Build primer on wings now
