JAMESs Web Site
Date:  1-23-2015
Number of Hours:  4.00
Manual Reference:  14.2
Brief Description:  Time to use the bondo in low areas
I got out the air board and sanded down the Micro on the winglets first thing and used the 3’ sanding aluminum channel to get things nice and straight. Next on the list was to mark all the low areas that will need bondo to level out. If I could see scratches or areas that was not sanded then this was marked for bondo. Evercoat Spot-lite was the filler I used due to its feathering on the edges and it did not clog the paper.
I will look over the wings one more time for any thing I missed any were and spray it one more time with primer to fill in the micro spots.
Spot-lite bondo is working out
Low areas filled in
Low areas filled in
Micro used in deep areas
