Brief Description: Working on fuselage stakes and fuselage radius
Icing was applied after the strakes were sanded for high spots. I’m getting very close to were it needs to be before primer is sprayed on. I also radius the fuselage to strake tonight with a tong depressor the micro was starting to set up in 25-30 minutes. This is OK for me it should be ready for sanding in the morning.
