JAMESs Web Site
Date:  1-18-2015
Manual Reference:  14.2
Brief Description:  Working on fuselage strakes
Tonight I did some quick sanding with the Dewalt orbital sander to knock off the high spots and checked with the 4’ straight edge for level and had to add more filler. The mold for the strakes at the factory is showing its aged not perfect but workable.
It will take a few applications to have it smooth and level.
I’m sure if I did this all the time I would build the ribs or stakes to work out more level if possible, some times you have to play the hand your dealt.
Another snow day 15cm 6" of heavy snow to deal with. Chain came off the back driver side plough wheel and took out the brake line. Changed the starter as well. Not a fun day just work, who said winter, was a time to hibernate. If that ground hog says 6 more weeks of winter I will fill his hole with quick set mortar.
A bit more micro added
Getting close to level
Copyright © 2001-2018 Matronics. All Rights Reserved.
