Brief Description: Fill bottom of wings with sandable micro
Well I had hernia surgery on Dec 18/14 and all went. I took some time to heal and got back on my feet doing a few things after Christmas. The time on the plane is not all at once but an hour here and there to do the work. As the Doctor said no lifting over 20 lbs. Resin and a sander is only 10 lbs so all is good. The bottoms of the wings were filled and sanded and then pin holes were filled and scaped off. I used a circular motion on the pin holes to fill in all direction and then I scraped off the excess. No sanding was needed to deal with this but I did run my hand over the wings and found areas that needed a light sanding once cured.
