Brief Description: Moved shop around again and sand door ends
I sanded and filled with micro to have the doors with a consistent gap. It is now time to move the shop around again to work on the doors. I tried to move the plane out but no luck. I will have to build a cradle and rotate the fuselage at a 45% angel to fit out the garage door so it will stay inside for the winter. I seam to have enough room to have the fuselage and wings in the shop all at the same time.
