It’s been some time since I worked on the plane. I finished the hell hole upper and lower on the pilot side and fit and installed the ribs from the back fuel bulk head to the main spar. This by far was the most challenging of all the lay-ups so far. The room to work in was very tight and the lay-ups on the pilot side took some time to get right. The end result was a good micro radius and 2 bib to keep it in place. The ribs were fit and micro-bid in place !!
