JAMESs Web Site
Date:  7-6-2014
Number of Hours:  0.00
Manual Reference:  9.4.3
Brief Description:  Working on strake
I got the laser out and lined up the cut for the door again and it came out good.
Moved onto the baggage area and cut and sanded to get ready for the lay-ups need to finish the compartment.
I set up to cut the wing free at the back of the strake, this worked out good.
I mixed up some filler and applied to the strake and wing to get the transition smooth.
After sanding the filler and the blend is good the wing will come off and the plane will spin to it new spot for the other strake to be done.
Door is cut and free
Filler added to blend, Bondo thick
Getting ready to finish baggage area
Copyright © 2001-2018 Matronics. All Rights Reserved.
