JAMESs Web Site
VELOCITY- XLRG
Install toe brake cylinders
The longer bolts I needed come in so the job was to install the toe brake cylinders. I used washers to space the cylinders away from the peddles to eliminate any rubbing. I need to plum the cylinders in now.
Toe brakes look good in the plane
Pilot side
Co-Pilot side
VELOCITY- XLRG Home
2528
Brakes
Bulkheads
Canard/Elevator
49
122
Control System
Doors/Windows
78
192
Electrical/Instrumen
Engine/Propeller
141
432
Fairings
Filling to priming
155
533
Final Assembly/Finis
407
194
Inspections
Instrument Panel
Kit Purchase/Conditi
Landing Gear/RG
Shop
Time away from build
Wheels/Axles
Wings/Winglets
