Brief Description: Fuel cap ground wire & prep for fuel proofing
I some how had forgotten to install the ground wire when I was installing the fuel cap. I drill a 1/8” hole from the top to get my land mark and then drilled the ½” hole from the other side. I then cleaned up with the dermal tool and used a 1/8” rod to drill a hole out from the cap to the back of the strake to run the wire. The wire was riveted in place and then filled in with micro.
I then cleaned up the Pilot strake for fuel proofing with resin.
