JAMESs Web Site
Date:  3-2-2014
Number of Hours:  3.00
Manual Reference:  9.3.1
Brief Description:  Fit and glass in section on wheel well
This side has been trying to get right. The Pilot landing gear leg is over a bit into the fuselage which means it will rotate into the fuselage more then the other side and so the fitting was a bit more of a challenge then the Co-Pilot side. After cutting and sanding it is very close to where it should be.
Glass in section
Glass in section
Add some from over cut
Wheel has 1/2
Wheel has 1/2" better clearance
