Brief Description: Lower strake half glassing to main spar
Tonight I mixed up some flox with resin and coated the lower strake and main spar where it comes in contact with the main spar. This time I used a 1x4 to hold the spar down when I jacked up from the bottom. The incidence move a little bit so I adjusted at the end of the wing to bring it back to level. I then mixed up micro glass and filled in the space between the spar and the lower strake. 2 bids was then wetted out and applied. Cynthia came home so I went down to the shop an hour later and put on the peel-ply to finish the job for today.
