JAMESs Web Site
Date:  2-20-2014
Number of Hours:  4.00
Manual Reference:  9.2.5
Brief Description:  Lower strake half glassing to main spar
Tonight I mixed up some flox with resin and coated the lower strake and main spar where it comes in contact with the main spar. This time I used a 1x4 to hold the spar down when I jacked up from the bottom. The incidence move a little bit so I adjusted at the end of the wing to bring it back to level. I then mixed up micro glass and filled in the space between the spar and the lower strake. 2 bids was then wetted out and applied.
Cynthia came home so I went down to the shop an hour later and put on the peel-ply to finish the job for today.
Lower strake being jacked up
Micro and 2 bid in place
Peel-ply 1 hour later
