Brief Description: Sand bulkheads and fill in over leg cover
The bulkhead need trimming and sanding from the extra bid (cloth) that was added to help with fuel containment. The mouse holes were sanded as well and a painting with more resin. Then I made a template out of cardboard to fill in over the gear leg cover, this is part of the fuel tank. I cut out a piece of covered foam left over from the baffles and bided into place with extra on the fuel side. Now I can work on the fuel bulkheads after the flanges are installed.
