JAMESs Web Site
Date:  12-29-2013
Number of Hours:  3.50
Manual Reference:  9.3.2
Brief Description:  90 degree flanges and moues holes
Here I’m making 90 degree flanges that will go on top of the bulkheads and baffles. I used the I beam that came with the kit and duct taped the bottom and laid in 2 bid then plastic on top with the 2x4 to hold into the corner.
The mouse holes were next for fuel and air to pass trough the baffles and areas in the fuel tank. The curves were micro-slurred with 1 bid to seal from fuel soaking in; more resin will be painted on later for a good fuel seal
I beams setup for flanges
Mouse holes with bid
Extra bid on both sides at leg opening
Copyright © 2001-2018 Matronics. All Rights Reserved.
