Brief Description: Cut out strake for tire and prep for leg cover
I finished cutting out for the wheel bit by bit. I took the tire up to 65 psi and cut the hole so that when the tire passes through the opening there is 1/2” clearance all the way around the tire. I then cut back the foam for the finishing bid to seal up the openings in the future.
