JAMESs Web Site
Date:  12-22-2013
Number of Hours:  5.00
Manual Reference:  9.3.1
Brief Description:  Cut out strake for tire and prep for leg cover
I finished cutting out for the wheel bit by bit. I took the tire up to 65 psi and cut the hole so that when the tire passes through the opening there is 1/2” clearance all the way around the tire. I then cut back the foam for the finishing bid to seal up the openings in the future.
Wheel opening cut out
Prep for leg cover bid work
