Brief Description: Cut out baggage area in the strake
I put the lower strake back into place after sanding and relocating the door location for the leading edge. The marks were move out and then back into the spot as to the manual. I went inside the fuselage and measured 18” from the gear bulk head and drilled true the side of the fuselage. The other marks I traced with the lower and upper strakes were in place. Used the cut disk to start and finished with the hacksaw blade. I now have to finish the bolt hole areas on the wing before I move on from here.
