The foam was removed to fit on the main spar and the wing. Before this gets put into place sanding and the hole in the side of the fuselage needs to be done. Going true the tapes on the building as I do quite often I notice that the cross lay-up on the wing bolt hoes was not done. So tonight the wing came off getting ready for the bolt hole lay-ups that I need to get done next week.
