JAMESs Web Site
VELOCITY- XLRG
Fit the lower Co-Pilot strake
Well I started to cut and fit the lower strake. The pre marked line were off as I found out. I had removed too much and had to put it back on. A small cut can make a big change on how things fit. More thinking time is needed for this job.
Manual said up 2- 7/8 from bottom of main spar
It turn out good for this one
The end I added back on
VELOCITY- XLRG Home
2493
Bulkheads
Canard/Elevator
49
122
Control System
Doors/Windows
78
192
Electrical/Instrumen
Engine/Propeller
141
432
Fairings
Filling to priming
155
533
Final Assembly/Finis
407
194
Inspections
Instrument Panel
Kit Purchase/Conditi
Landing Gear/RG
Shop
Time away from build
Wheels/Axles
Wings/Winglets
