JAMESs Web Site
Date:  11-30-2013
Manual Reference:  9.2.3
Brief Description:  Lower strake alignment
I leveled the main spar and followed the instructions as to the manual with a level line from the bottom of the main spar up to the doors. I used a water level to see if both side worked out. The out come was good and will leave it as is for the strake front spot on the door.
Pilot side is on
Pilot side is on
Co-Pliot side is good also
Main spar is level
Main spar is level
Copyright © 2001-2018 Matronics. All Rights Reserved.
