Brief Description: TRIAX on dog house for hold down hinges
A few of the builders are using piano hinges to hold on the dog house so I will do the same this way you don’t see any screws because it is held from inside with the hinges. I will use stainless steel to hold the two hinge haves together and lock it in place.
