JAMESs Web Site
Date:  11-28-2013
Number of Hours:  1.00
Manual Reference:  6.8.2
Brief Description:  TRIAX on dog house for hold down hinges
A few of the builders are using piano hinges to hold on the dog house so I will do the same this way you don’t see any screws because it is held from inside with the hinges. I will use stainless steel to hold the two hinge haves together and lock it in place.
TRIAX in place
TRIAX in place
The hinge needs to fit flat on the lay-up
