Brief Description: Time to fit the canard onto the fuselage
I needed to move the plane to work on mounting the canard onto the plane. So out of hand me down stuff I cut the chip board and picked up the rest at a local lumber yard. I will need to trim the fuselage to fit the canard at the front. Once it fits good then I will adjust ever which way to be in the right spot and then bondo into place for me to drill the holes into the bulk head from the mounting plates on the canard.
