JAMESs Web Site
Date:  5-20-2013
Number of Hours:  1.50
Manual Reference:  6.2.3
Brief Description:  Tap seat belt hard points
On the seat belt hard points I will be taping in place and not before hand. I drilled out the excess resin inside the 3/8” hard point holes and made sure I did not go true the fuselage on the body ones. My Dad showed me the trick of hammering on a nut on the end of the tap to use a ratchet on it to tap the hole and it always work well. I pulled the foam out of the fuselage holes with a hook to see my depth when tapping. I used tap and cut oil on the job and that stuff is amazing when cutting treads.
Tap with nut on end work great
Foam pulled out of hole for right dept.
