JAMESs Web Site
Date:  5-12-2013
Number of Hours:  1.75
Manual Reference:  5.2.0
Brief Description:  Foam for door kick plate
I will be using foam to make the door kick plates. I micro glassed the foam into place after shaping. I will need to file and sand to shape install wood dowelling for the aluminum strip on top to screw too and than do a 2 bid lay-up to finish this off.
Foam shaped and micro in place
1" aluminum strip will go on top
Copyright © 2001-2017 Matronics. All Rights Reserved.
