Brief Description: Milled fiber in hard points with 3 bid
Saturday morning I mixed up milled fiber and resin and installed all the hard points. I then did a 3 bid lay-up on all the points. Next was peel-ply on all the hard points. When I pressed the hard points into place the center hole had resin ooze out and that had to be removed. I a few days I will re-drill the 3/8” hole and tap for the 7/16” fine thread bolts.
