JAMESs Web Site
Date:  5-9-2013
Number of Hours:  2.50
Manual Reference:  6.2.3
Brief Description:  Prep hard points for seat belts
It time to work on the hard points for the seat belts. I centered and drilled for the 7/16 seat belt bolts. I used a 3/8” drill bit for the fine threaded bolt. I then ground the aluminum to rough surface and sanded the fuselage for a good bond with the milled fiber resin mix. I will be using the inertera seat belts so a hard point had to be located under the carbon fiber beam bolt.
Front hard points
Front hard points
Fuselage sanded and ready for hard points
Bottom ones are for the back
