JAMESs Web Site
VELOCITY- XLRG
Back seat hard points
I cut out the inner glass for the hard point on the outer ones and removed foam so that the seat sits level. I ground out holes for the bolts and got ready for the hard points to be installed. Mixed up milled fiber and resin and glued into place.
Cut and ground out for hard points
Hard point taped and ruffened up
The tires did somthing to night
VELOCITY- XLRG Home
2528
Brakes
Bulkheads
Canard/Elevator
49
122
Control System
Doors/Windows
78
192
Electrical/Instrumen
Engine/Propeller
141
432
Fairings
Filling to priming
155
533
Final Assembly/Finis
407
194
Inspections
Instrument Panel
Kit Purchase/Conditi
Landing Gear/RG
Shop
Time away from build
Wheels/Axles
Wings/Winglets
