JAMESs Web Site
Date:  1-25-2013
Number of Hours:  1.50
Manual Reference:  9.5.2
Brief Description:  More resin on header tank
I did one more bid on the tank to make sure it will be sealed and wet the whole thing out. I will need to do one more coat of resin on the out side and then it will be time to position in the fuselage and make the mounting tabs for it. I seen on other person move the drain cock from under the tank to 2.5’ forward and off to the side for easier access and off the bottom of the fuselage just in case of a belly landing.
Fuel header tank
Fuel header tank
Copyright © 2001-2017 Matronics. All Rights Reserved.
