I used 5/16 truck airline tubing as a protector for the brake lines. The lines were glued on with hot glue. Hot glue is amazing stuff for holding things in place. Every thing was sanded and I used micro to radius the lines and then to bid on to hold it in place. One thing I have learned is that the bid will not sit in 90 degree corners to well so it is much easer to radius every thing if you can,
