-Finished backriveting all the pieces except for the 4 corner steel brackets.
-Drilled out and re-riveted a couple oops
-Started backriveting the 4 corners. Ended up using my long backrivet set so I could stay straight on the rivet (the gun would hit the tall flanges). The plans have a mistake in them. On one part of the plans it calls for -6 rivets and then -7's on another, even though it's all the same thickness of parts. After smashing some -6's, I determined the shop head was getting a little thin, so I had to drill some out and make them all -7's. Then I bent a few over and had to drill those out. Geez, seems like I'm a little out of practice. Will finish these tommorow.
Everythink clecoed together
Putting the riveting tape to use holding in the rivets before flipping it over
Using the long backrivet set near the corner flanges
