Brief Description: Installed conduit and Transponder Antenna
- Installed the wiring conduit on the right lower side of the fuse. This will carry alot of wires for the ADAHRS, transponder, servos, etc. - Installed the transponder antenna. Since the transponder is a remote unit, it allowed me to locate the antenna towards the rear and keep the cable run to the antenna very short (ideal).
Transponder antenna installed in aft portion of fuse
