Brief Description: Aft Upper Skin and Bulkheads #4
- Modified the aft ends of the shoulder harness anchors so they fit over the F-808 bulkhead flange - Cleco’d the shoulder harness anchors in place - Final drilled the #30 holes in the skin/shoulder harness anchors - Final drilled #40 the holes in skin/bulkheads, and canopy rail receptacle - Crawled into the tail and drilled the right side holes on the ADAHRS mounts while the skin was in place -Uncleco’d the aft skin/shoulder harness anchors - Final drilled #40 the 3/32 holes along the edges of the aft top skin that were common with the side skins/longerons that were already final drilled/dimpled - Final drilled #30 the holes between the bulkhead gussets and the F-807 bulkhead. Also, drilled the holes from the bulkhead gussets through the upper longeron (the directions forget to tell you to do this, in a later step they tell you to debur the holes they never told you to drill) - Uncleco’d and removed all the bulkheads/parts
