Got out the F805E rudder cable support brackets (L/R) and deburred and countersunk for the nutplate that goes in each one and againg sat them aside for priming. Then I strung the rudder cables per the plans starting from the back of the aircraft and added the grommets as I went. Anchored the plastic tube at the exit hole, and clecoed on the exit guide covers. Will need to rivet those when I get someone to help me...to far to reach alone.
Support brackets fabricated and ready to install
Kind of hard to see, but there's rudder cables in there...
Cable attached to rudder. Note the exit guide cover cleko'd on still.
