-Received the new flap bearing blocks I messed up on 3/4/11 -This time I used the floor skins to mark and drill the blocks, they turned out perfect. -Used the newly located and drilled holes in the blocks to drill the forward hole through the outboard seat rib angle and installed the nutplates using cherrymax rivets -Floors are finally done!!!!
Rear section of floor and flap actuator weldment in place
Looking down onto the right side, the fwd hole in the block will be used to drill into the seat rib
Match drilling the outboard seat rib...broke out the angle attachment...
