-Marked off and drilled the alignment holes in the hinge as noted in the drawings. -Cleco'd the hinge on and drilled the hinge rivet holes. -Bent the top of the F833C with the flanger per the plans -Cleco'd it all together and match drilled the whole thing -Dissassebled it
