Started work on the Forward Bottom Skins. Once I get these done it will be time to flip the Fuselage back over for the last time...hopefully...
-Final drilled the 1/8 holes in the F851s (L/R) and deburred and dimpled per the plans - watch out the most fwd one dimples reverse from all of the others (see plans) -Cleco'd the bottom skins in place -Marked the holes on the bottom skins that are common with the screw holes on the bottom edge of the side skins
