Leaving this afternoon for Tucson, AZ, but got a little time in the garage first...
-Deburred the cut areas on the F832Bs -Removed the tabs from the seatback per the plans (dremel with thin cutoff wheel) -Edge deburred everything -Cleco'd the hinge to the seat back and drilled the opposite end 1/8 hole -Cleco'd the support angles, horizontal and vertical, to the seat back
