Todd's Web site
Date: 11-27-2010
Number of Hours: 2.35
Manual Reference: 8-36 & 8-37
Brief Description: Fuselage Riveting #19 (and rear battery tray)
No riveting partner today, so I was relegated to a few things I can do by myself...
-Finished riveting the mid-side skins around the around the spar openings with a squeezer -Installed the little bulkhead bracket in the elevator bellcrank area. The plans called for the use of AN470AD3-4 rivets (small button heads), but the kit doesn't provide any. So I drilled the 4 holes where you see button heads to #30 and installed AD4-4 rivets. On the side rivets, I dimpled the holes and installed AN426AD-3.5 (countersunk) rivets. It aint goin' nowhere. -Went ahead and cleko'd together, drilled, countersunk, deburred, scuffed, primed, assembled, and installed the rear battery tray mount. Since I'm planning an O-360 with a lightweight fixed pitch prop, I'm not planning on installing a rear battery, but the nutplates are already installed on the baggage ribs, and it could provide a handy place to mount some equipment later. Plus in case I do decide to put the battery in the rear, it's there.
Getting ready to go on another TDY for a few days, but will be itching to work on it as soon as I get home!
Squeezing the rivets around the spar opening on the mid fuse side skins
Installed the bellcrank rib up in the baggage ribs
Assembled and mounted the rear battery tray...even though I'm planning on a firewall mount...
