Todd's Web site
Date: 11-11-2010
Number of Hours: 6.50
Manual Reference: 8-35
Brief Description: Fuselage Riveting #9
Well...after family crisis', camping trips, numerous TDYs, vacations, holidays, broken bones (5 yr old), car problems, and a thousand other excuses, i finally got back on track on the build. I was really getting anxious not being able to work on it...it feels good to be back at it!
-Put a bead of Fuel sealant along the firewall where the fwd skins overlap. -Cleco'd the fwd skins, F844 aux longerons, F802F spacers and F802D ldg gear box plate to the fuselage (L/R) -Put the 2 blind rivets into the mid side skin and center section near the spar opening per the plans (L/R) -Cleco'd the F848 upper longeron gusset along with the F846 and F845 gussets (L/R). -Cleco'd the F807 bulkhead into position -Rivetd F807 to the F813 outboard seat ribs. -Riveted F818B baggage rib angles to the F818 baggage ribs (L/R) -Riveted the 3 nutplates to to the F818B baggage rib angles -Rivetd the F818 baggage ribs to the F807 bulkhead and F814 inboard seat ribs -Riveted the three nutplates to the F-888 mid longerons (L/R) -Primed one of the large F-825 aft side skins and installed the four nutplates for the rear cover plate opening.
Forward skins cleko'd on with sealant
Installed the blind rivet per the instructions
F-807 bulkhead cleko'd on
