-Enlisted the help of the neigbors to lower the fuselage to stands/sawhorse I figured out last night. Kids thought it was cool to be able to see into the fuse. -Final drilled the #30 holes in the bottom skins where they join at the F804 center section bulkhead assembly. -Cleko'd the bulkhead tops on the aft fuse.
Fuse lowered
Bulkhead tops cleko'd on
I noticed Payden with my Dynon brochure...then I later found this...he came up with this on his own...
