-Match drilled #40 the mid side skins and the upper longerons (L/R) -Final drilled #30 the rest of the 1/8" holes in the mid side skins (L/R) -Final drilled #40 the rivet holes in the aft end of the mid cabin bottom skins where they join the tail cone -Final drilled #40 the bottom of the tailcone (both F842 and F828) -Started drilling the #40 holes in the aft side skins where the upper longerons attach. Got the right longeron done...sure is alot of holes that will require alot of countersinking... -Kaitlyn helped me out again today when I was drilling the aft skin to the right longeron. She's a hoot!
She would hide the cleko and pliers behind her back until I needed them, then yell out SUPRISE!!!
Posing...I thought we had got rid of all the pacifiers...
