- Riveted the Fwd and Aft inboard seat ribs to the rear spar attach bulkhead assembly. Wasn't the prettiest riveting job, but everything turned out sound. Lesson learned...when it's been 6 months since you've ran a rivet gun, you shouldn't put rusty skills to the test in a tight spot with an offset rivet set. Took me an hour to shoot 8 rivets, then another half hour to drill out and redo of them!
Inboard seat rib assemblies riveted to the rear spar attach bulkhead...whew...that took way too long!
